Use the following procedure to display BFD configuration on an interface.
The following example displays VLAN interface configuration information for BFD.
Switch:1>show ip bfd interfaces vlan 11 ========================================================================================== Vlan Bfd ========================================================================================== VLAN STATUS MIN_RX INTERVAL MULTIPLIER VRF-ID ------------------------------------------------------------------------------------------ 11 enable 200 200 3 0
Switch:1>show ip bfd interfaces loopback ================================================================================ Circuitless IP Interface Bfd ================================================================================ INTF ID STATUS MIN_RX INTERVAL MULTIPLIER VRF-ID -------------------------------------------------------------------------------- 1 enable 200 200 3 0 2 enable 200 200 3 2
The following table defines parameters for the show ip bfd interfaces command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
<1-4059> |
vrf WORD<1-16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0-512> |
Specifies a VRF or range of VRFs by ID. |
